k24 map anbody?
k24 map anbody?
i was wondering if anybody had a base map for a k24 k20 with a 70mm tb and 410 injectors? ..i reseached the hondata website but no luck...any help will be good ...because the one i have this makes the car stall at 2000rpm any help will be good thanks
Re: k24 map anbody?
what i did was downloaded the k-pro program from the hondata website.. went into new calibration found one closes to my set-up and ran with that one.. i also had 410 injectors so i adjusted the fuel trim to 410.. worked fine for me just to drive around and get to a tuner..
Re: k24 map anbody?
yes i did the same thing ,the car was runnin fine until i put the rbc manifold with the bdl 70mm tb.....so am thinking i just have to add some fuel to the kal right?
