K20 in EG6 spring questions
I know if you swap a K20 into an EF you will need to get some stiffer springs to support the extra weight of the engine, but is this also true for an 94 hatch? and if so will just swapping to some aftermarket or springs/coilovers do the trick? Any input will help alot, thanks in advanced.
Re: K20 in EG6 spring questions (Blue_DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue_DX »</TD></TR><TR><TD CLASS="quote">I know if you swap a K20 into an EF you will need to get some stiffer springs to support the extra weight of the engine, but is this also true for an 94 hatch? and if so will just swapping to some aftermarket or springs/coilovers do the trick? Any input will help alot, thanks in advanced.</TD></TR></TABLE>
Yes, it is the same, just not as much since EGs are slightly heavier than EFs. You will need stiffer springs/coilovers on the EG.
Re: K20 in EG6 spring questions (fast95eg8)
my last post was a bit mean...
go to gc and get the spring/coilover kit for your car with a swap
or just call up gc and ask them what spring rates you should get...
if you have a k... gc shouldn't be "pricy"
Omega Blaze
12
08-05-2008 07:50 AM
ZAKU
Suspension & Brakes
05-01-2008 01:46 AM
