Just screwed myself, need advice!
I was just about to get this hatchback I bought rolling and I was changing the front LCA and disaster strikes.
http://www.hondaautomotiveparts.com/...RONT+LOWER+ARM
Part number 20 was seized and I used the impact because the socket wrench was impossible and the tap that is welded to the frame busted free now the bolt is still connected to it and it spins free but the tap is no longer welded to the frame. Is there any way to fix this or did I just **** myself out of ever driving this car?
I was thinking that maybe driving without it may be ok because there is two other bolts holding it to the frame at that one point. Then again I dont want to die because of it. The only thing I can think of is dremeling out a square around it and welding on a new tap to it and welding the square back up. Any advice here?
Re: Just screwed myself, need advice!
Same thing just happened to me, oddly enough. I think we're both kinda screwed...unless you can cut a hole and put a new nut and fender washer in there...
Just so you know, you can change the front LCA without removing that bracket. There's a nut on the back to pull it out of the bushing.
Thanks to anyone that can help. I mean this could happen at any shop. There has to be a way to at least ghetto rig it and it still be safe.
im guesswing u have a weleded nut on that right??? well bust out the grinder if u can reach with it in there and cut that bolt off and put in a new screw with a nut on the other end. dosent have to be welded on but a locking washer will also help..
hmmm I wonder where about on the firewall. Some1 has had to deal with this before and fixed it... There are a few entry points I feel like I could get to the nut. So can any1 confirm for sure there is a nut holding it in?
The bolt snapped off in the threaded part, right? Just pull that out (or leave it, I don't care) and put a new nut in. I just picked up some 5/8" grade 8 bolts and nuts.
I talked to a friend of mine who works on jeeps and he suggested welding a nut to a plate and sticking that in there and welding it back up. If you have access to a welder, do that. Otherwise, make as small a hole as possible to get the nut and a wrench in.
I looked, there's really no place to put a wrench in. You gotta cut it.
Seagull Management
I had the nut break off in there before but I was stripping a civic for parts before it went to the crusher, so I just cut a big hole in the firewall with an angle grinder.
Trevor Duncan
05-29-2019 12:34 AM
Deano_D aka "Brick Top"
14
02-21-2005 12:37 PM
