Just got my 98 ITR cams, 00 ITR valve springs, skunk2 Ti retainers installed...
Well just got my new parts installed on my si, they were the 98 spec ITR cams, and 99 ITR valve springs, skunk2 Ti retainers....got them installed by CivicEK.PDX in Portland...did a real good job for a good price....highly recomend him for anything to install....
Opin of mod so far is i can feel a difference but i feel like there is a ton more power to be tapped by a CTR ecu and VAFC which are my next planned install....peaace
Re: Just got my 98 ITR cams, 00 ITR valve springs, skunk2 Ti retainers installed... (00civicsimobsty
sweet, i want to do the same set up in the b16 i have for my hatch. good luck with it.
If your in the northwest...i make it worth while to drive down to where I am at. the price and quality of work is top notch. Thanks to Brandon for the good words .
You should have goten 00-01 ITR cams the intake cam on the 00-01 has a bit more lift they are identical to the CTR cams. But none the less you should see about 10 or so WHP from them mabe more depending on how tuned
big strong guy
why get a ctr ecu? you will make more power converting to obd1 and running chiped ecu!! check my sig!! kenjis the man!! good luck, eric
CTR ecus plug in play to 00 Si's. Also they run perfect. You would never have to worry of any problems. And they disable the 2nd O2 sensor and all emissions crap. Plus they still retain OBD2 and rev out to 8800
i got that whole set up for my next project(ls vtec in the works) hopefully it will let my motor breith and land me in the low 13's
nice avaitor ForceFedEG
Location: Toronto, Canada currently residing in ATL, GA, USA
If its from a Japanese market CTR then have fun till 120 mph. Unless you had the limiter removed.
b16powwer
10-20-2002 10:49 PM
00civicsimobstyle
09-11-2002 11:17 PM
