just bought my EG
just bought my EG
hey i just bought my EG and the hood is all the way closed but there is a gap in the front only i think it was in an accident can any one help how do i fix the gap
Re: just bought my EG (Hondahatch4eva)
I've been looking for a hatch but we don't have the greatest selection up in here in New Brunswick, Canada....we got trees though whoopee
If it is a small gap you can adjust the two rubber bumpstops(dont know real term) to make it sit lower. My car had this issue, but all is good now.
Good luck,
Jayson S.
Good luck,
Jayson S.
my hatch is the same way pull the front bumper off and you can tell if it has been hit in the front.. i found out once i pulled the bumper off. the front bar was totally smacked!!!
Re: just bought my EG (jdmeg6turbo)
yeah i tried everything to try to get it all straight. but that bar down by the radiator was a little bent. does that mean the front of my car will never be straight ???? or can this be fixed
Anything can be fixed, just whether or not it's worth your time and money. If the car drives true, it may be a good sign that the frame isn't damaged. But you should still get it checked out by a reputable body shop. As for the hood, you should be able to adjust the rubber posts, as mentioned above. They screw in to lower the hood, and you can kinda unscrew them to raise how the hood sits. You might also want to check the hood mechanism that holds the hood down when you close it.
if i were u i will try to allign out the head lights because my projector light was hiding the hood and also where the hood locks adjust that,hmm and also where your hood is hold adjust that try some spacers if it helps. Last is adjusting those black rubber piece on the radiator bracket dont know what those rubber peace call sorry
Caymnite
05-05-2011 02:37 PM
