j's intake on b18c swap...FINAL VERDICT!
i have done much searching and have not come to a final conclusion. i have a gsr engine in my ek hatch and want to know if the real j's racing intake will fit around the throttle body and in the space provided. if not then what mods needs to be done for it to fit properly. thanks for the help
Re: j's intake on b18c swap...FINAL VERDICT! (tyflip2)
i'm not sure about your question, but i have one for you. i just recently bought a 2000 hatch, and i was planning on doing either an H22 or a Gsr swap. Have you taken your car to the track, and if so what times have you posted up? also are you pleased with the power your Gsr swap has produced in your ek Hatch?
Bump for the info bro
Re: j's intake on b18c swap...FINAL VERDICT! (airteck371)
the power is very nice and i am very pleased with this swap. i have plans to turbo it sometime in the future and would recomend this swap to anyone. although the H22 can make some impressive numbers. back to the topic...is this possible to have the j's intake or is a new IM needed. help please. thanks
yes, it is possible to have a j's inatke on your gsr manifold. i'm running one in my hatch with a b series swap
it comes with an adapter piece that is shaped from small to large, so the small end fits on your manifold and the large end on the intake.
Re: j's intake on b18c swap...FINAL VERDICT! (cre18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 »</TD></TR><TR><TD CLASS="quote">yes, it is possible to have a j's inatke on your gsr manifold. i'm running one in my hatch with a b series swap
it comes with an adapter piece that is shaped from small to large, so the small end fits on your manifold and the large end on the intake.</TD></TR></TABLE>
Is there going to be enough room with the GSR intake mani, since the throttle body sits so low in the engine bay, and the fat J's intake has to snake around the shock tower
Re: j's intake on b18c swap...FINAL VERDICT! (rodrez)
I have a gsr swap in my 97 hatch, I am using a sk2 manifold, itr throttle body and j's intake fits like a glove
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez »</TD></TR><TR><TD CLASS="quote">
Is there going to be enough room with the GSR intake mani, since the throttle body sits so low in the engine bay, and the fat J's intake has to snake around the shock tower </TD></TR></TABLE>
lol, this whole time i was thinking intake manifold
Re: j's intake on b18c swap...FINAL VERDICT! (JUN EK9)
what all did you have to do to put on the skunk2 intake manifold. i heard you have to get a new itr cable and move the rotor and what not. is this ture or does the skunk 2 manifold just bolt right up. how do you like the combination. can you feel a good power gain??
I used my GSR cable, a 93 CX rotor and made a cable plate/holder out of some scrap metal.
works like a champ
works like a champ
You can use the GSR throttle cable on the Skunk intake mani, I did for about a year, but I changed it, I prefer the TypeR cause it looks cleaner.
it will fit. just order whatever intake is for the engine, it will all fit fine, especially on a short ram intake
I have a Injen RD cai one piece intake on my JDM B18C engine in my 99 civic hatch.. it's made for the engine and fit's perfectly. no modifications needed.
All the engine bay layouts are practically the same.
hmmm....i'm wondering about this intake thing now. i have a 91 hatch with a built motor and well...here's the engine bay:
do they make a J's intake for this chassis?
i may have to relocate my battery though...weak sauce...
that throttle cable looks pretty jacked....i'm gonna have to replace that thing
Re: j's intake on b18c swap...FINAL VERDICT! (acydphryck)
http://it will fit. just order whate....<br />
<br />
the thing is that they dont make the j's intake for a gsr... i just need to know if you need the skunk 2 manifold to properly install the j's intake on the gsr engine or if it will work fine even though the throttle body is so low. i also need to know if the skunk 2 manifold bolts right up and i still can use my stock cable and stock throttle body. thanks for all the help
Re: (sivik2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivik2nr »</TD></TR><TR><TD CLASS="quote">it will fit. just order whatever intake is for the engine, it will all fit fine, especially on a short ram intake
Right, but the J's intake is not shaped like a regular short ram or cold air intake, it bulges out quite a bit in the middle.
All the engine bay layouts are practically the same.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">hmmm....i'm wondering about this intake thing now. i have a 91 hatch with a built motor and well...here's the engine bay:
that throttle cable looks pretty jacked....i'm gonna have to replace that thing </TD></TR></TABLE>
If you relocate the battery, then a J's intake for the SiR should fit. It'll place the filter right behind the passenger headlight, just above that factory hole.
Re: j's intake on b18c swap...FINAL VERDICT! (Halo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo »</TD></TR><TR><TD CLASS="quote">I have a gsr swap in my 97 hatch, I am using a sk2 manifold, itr throttle body and j's intake fits like a glove</TD></TR></TABLE>
so how does the j's intake perform with your current setup? do you have dyno numbers prior to the j's intake and numbers now?
Re: j's intake on b18c swap...FINAL VERDICT! (eg6si)
is there a gsr "version" of the j's racing intake. some people say that there is and some say it doesnt exist. i am having a hard time finding one. would you recomend the skunk 2 manifold with bigger throttle body and j's intake as far as performance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6si »</TD></TR><TR><TD CLASS="quote">
so how does the j's intake perform with your current setup? do you have dyno numbers prior to the j's intake and numbers now?</TD></TR></TABLE>
So far I am making 197.3 whp using ctr cams, but am in the process of switching to Toda C's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 »</TD></TR><TR><TD CLASS="quote">is your b series swap a jdm b18c gsr engine??</TD></TR></TABLE>
usdm b18c5
usdm b18c5
just yesterday i installed one on a GSR motor with a Skunk2 Intake Mani, thinking about the fitment i DO NOT think it will fit. GSR throttle body sits too low. Prove me wrong and post pictures if it works!!
-Bryan-
-Bryan-
Re: j's intake on b18c swap...FINAL VERDICT! (xXMoMo77Xx)
does anybody have any pics of the skunk 2 mani with the j;s intake on a GSR so we can all visualize the clearance issues. thanks alot
