JDM ZC Motor OBD1
JDM ZC Motor OBD1
Hey, what ecu do i have to use for a JDM ZC dohc Motor OBD1? will a p06 ecu work perfectly without any cel and idling correctly?
Modified by oxSLEEPERxo at 8:55 PM 10/20/2005
Re: JDM ZC Motor OBD1 (krazySOHC)
That was going to be my guess, but are you sure the LS ECU is the right ECU for the DOHC ZC or your just saying it cause it will work?
Re: JDM ZC Motor OBD1 (d15singlecammer)
Do not use an OBD1 LS ecu. I tried this with my ZC in my del sol and it ran rich and was sluggish. The timing and fuel maps are for a totally different head design, block displacement, intake manifold and spark plug. Get a P06 ECU, and put in a P29 program. That's a stock OBD-1 ZC program.
When I did my ZC swap into my del sol, I used a P06, then chipped it and put in a stock P29 program. it ran great, and like stock.
edit: My car idled like stock on a P06 and ran OK, although I could tell it wasn't at its optimum performance, and that's when I went ahead and chipped it and put in a ZC program.
Katman says to use a 14400-PK2-004 for the timing belt - 88 Prelude 2.0.
link: http://hybrid2.honda-perf.org/tech/zcinfo.html
i heard that the pr4 ls ecu will work, but its going to be running rich, trying to find the correct ecu for it where it runs perfectl, i know that there are p29 for it, but its not easy to get ahold of
Re: JDM ZC Motor OBD1 (oxSLEEPERxo)
Correct, however a chipped P06 running a P29 program is alot easier to come by. The LS ecu will never be able to adjust short or long term fuel trims enough to compensate for the difference in displacement, much less the entire difference in the design of the engine - b series vs. d series. Ultimately, you would really be fouling plugs and wasting gas if you went the LS ecu route.
yea....the pr4 ran a little rich but this was awhile back when ecu chipping wasn't that popular...
i tried both the p06 and pr4...seemed to like the pr4 more
Castanza
11-22-2006 03:27 PM
