jdm vtec solenoid...no mesh screen inside?
i am having vtec problems...so i decided to take off the solenoid and check the mesh screen like i was told.
i took it off...but i dont see any mesh screen.
its a vtec solenoid from a 97 jdm b18c
are ALL vtec solenoids supposed to have it? could this b the cause of my no vtec problem.
Re: jdm vtec solenoid...no mesh screen inside? (akteamster)
i have seen some without the screen but i have the screen on mine but i dont think the screen whould enable your vtec 2 engage. maybe low oil? not enough oil pressure . or it may just be the seloniod it self! try a freinds its worht a shot
Re: jdm vtec solenoid...no mesh screen inside? (EJ1_203)
oil level is fine. solenoid works...i ran power straight too it and it clicks...like its supposed too. pretty much out of ideas.
Well, considering I have never seen one that has a screen on the top section like that, I would say you are fine. Remove the solenoid itself from the head, you will find your mesh screen there.
Re: jdm vtec solenoid...no mesh screen inside? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">Well, considering I have never seen one that has a screen on the top section like that, I would say you are fine. Remove the solenoid itself from the head, you will find your mesh screen there.</TD></TR></TABLE>
oh, i thought that is where the screen is located. so your telling me its not there but i have to remove the unit completely?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akteamster »</TD></TR><TR><TD CLASS="quote">
oh, i thought that is where the screen is located. so your telling me its not there but i have to remove the unit completely?</TD></TR></TABLE>
I'm telling you there IS a screen, but not there and yes, you need to remove the whole unit completely to find the screen.
correct!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
I'm telling you there IS a screen, but not there and yes, you need to remove the whole unit completely to find the screen.</TD></TR></TABLE>
there should be a screen there, a little circleone and the lower solenoid part has another one. take gasket out maybe, try and change your oil and drain through screen to see if its in there.
Re: jdm vtec solenoid...no mesh screen inside? (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">there should be a screen there, a little circleone and the lower solenoid part has another one. take gasket out maybe, try and change your oil and drain through screen to see if its in there. </TD></TR></TABLE>
I had a few of those apart in my day and have NEVER seen one with a screen on the top section.
I also see no screen shown in the top part of this diagram either.
CompressionFed
03-23-2004 04:54 AM
