JDM P73 need help
JDM P73 need help
i have a ek witch is OBD2b and swapped a OBD2a GSR engine with jdm type r cams and pistons. I'm running it on the P72 with a jumper harness(OBD2b-OBD2a). Now i have a JDM P73 i think its a 97 spec, it's OBD2a cuz it plugged rite up to my jumper harness(witch is OBD2a). I started it and it didn't ideal. so i tryed again gave it some it was miss firing. after that it didn't start up. now i did the ckf bypass trick. WHY WONT IT RUN GOOD WIT P73???
Re: JDM P73 need help
kinda hard to figure out what your saying with all the words missed spelled. did you ever get it started with the p73? if not it could be an immboliser. i thought the jdm 2000 and 2001 had them i could be wrong. or try to hook it up with out jumper harness
na jdm ecu dont have immbolizer. yea it start up once then i try it again and didn't . basically i want to know if i need to wire anything different for the P73
allaboutgsr
13
03-17-2003 04:24 AM
