jdm itr swap in an eg?..
im planning to put a jdm itr swap in my eg and ive heard that im gonna have problem w/ the axles...how do you guys go about the axles problems?..can i run gsr axles w/ the itr tranny or do i have to run use the itr hub?..
Re: jdm itr swap in an eg?.. (e she i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e she i »</TD></TR><TR><TD CLASS="quote">im planning to put a jdm itr swap in my eg and ive heard that im gonna have problem w/ the axles...how do you guys go about the axles problems?..can i run gsr axles w/ the itr tranny or do i have to run use the itr hub?..</TD></TR></TABLE>
I'm like...70% sure the GSR axles will work fine.
Re: jdm itr swap in an eg?.. (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Any USDM hydro b-series axles will work. Simply any 94-01 Integra, 99-00 Civic Si, or 94-97 Del Sol VTEC.</TD></TR></TABLE>
I know you don't need someone to concur..but this is correct information.
Re: jdm itr swap in an eg?.. (I Shot 50 Cent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent »</TD></TR><TR><TD CLASS="quote">
I know you don't need someone to concur..but this is correct information. </TD></TR></TABLE>
It's always good for the OP to have someone back up someone else (for confidence level).
It's always good for the OP to have someone back up someone else (for confidence level). </TD></TR></TABLE>
True, but I don't want to be condescending to the person that originally stated the correct information. I don't want it to seem like your information cannot hold its own ground, and someone has to "concur" to make it more valid.
All good though
All good though
All good though </TD></TR></TABLE>
I don't mind, unlike some members.
Just thought I would add, 98+ jdm type r axles will not work unless you have jdm itr 5lug hubs (outer cv joint splines are bigger).
Re: jdm itr swap in an eg?.. (highroller54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 »</TD></TR><TR><TD CLASS="quote"> Just thought I would add, 98+ jdm type r axles will not work unless you have jdm itr 5lug hubs (outer cv joint splines are bigger).</TD></TR></TABLE>
so can he use 98+tranny itr with any us hydro axles? basically are the axles differnt on the tranny side too, or just the hub side?
Re: jdm itr swap in an eg?.. (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
so can he use 98+tranny itr with any us hydro axles? basically the axles are just different on the hub side?</TD></TR></TABLE>
yes
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 »</TD></TR><TR><TD CLASS="quote"> (outer cv joint splines are bigger).</TD></TR></TABLE>
thanks i should have just read the whole thing...
so can he use 98+tranny itr with any us hydro axles? basically are the axles differnt on the tranny side too, or just the hub side?</TD></TR></TABLE>
thats what i was trying to figure out...didn't know if i can use any b series hydro axles w/ the itr tranny..
Dave99si
04-20-2005 07:03 PM
