JDM Headlights
JDM Headlights
I got a set of JDM headlights with day time running lights in them. I want the daytime lights to turn on when the car turns on. That mean s that I can't directly wire it to the battery. What is your best suggestion to get then to turn on when the car does? Thanks
Re: JDM Headlights (boostedcivicsir)
That will work but do you really want to hook something else up to you fuel pump, I think that the best way is to wire them up to the ignition wire under the dash. I dont remember the color wire right off hand but it is in the main hareness going under you dash to the steering column. I will check tomorrow if you need the corect color.
Re: JDM Headlights (EG-cellent)
if your wastin time running wires into the car use the one of your cd player, you would be fine hookin it up ot any of the sources mentioned just use a relay so the power draw isnt to high
evolvedAP1
07-12-2006 11:18 AM
DIRep972
11-12-2001 08:24 PM
