jdm gsr and usdm gsr
is there a difference between the two as far as water lines go?
i've see some gsr blocks that have a water line coming out the block and two water hoses coming out the main water line.
on my jdm gsr motor, i don't have a water line coming out the back of the block, but i have an extra one coming out the main water line...
Re: jdm gsr and usdm gsr (hondaeg8)
Re: jdm gsr and usdm gsr (^Jae)
i think you are referring to the oen oil cooler set up, it has two nipples coming out of the water tube that connest to the oil coller right beind the oil filter. becasue there is no difference between the two engines except one vacuum line that goes to the evap purge solenoid, the collant hoses are the same
Re: jdm gsr and usdm gsr (built562)
usdm has the heater port on the t-stat housing, and the jdm has the outlet on the water pipe above the oil filter. just run a new hose!
TwoKSiR
05-02-2007 01:43 PM
