jdm gsr motor
jdm gsr motor
what all sensors need wired in to make usdm ecu work? i have a knock sensor blowing a cel is it not wired or is it just detonated? and for some reason the crank sensor that should throw a cel has not. im totally lost please help lol
Crazy Honda Guy
Re: jdm gsr motor
Not sure about your wiring issue, but if i were you, i'd source out a jdm P72 ecu. The jdm GSR uses higher compression pistons bringing compression up to 10.6:1.....exactly the same as a usdm Type R.
The sensors on both motors should be eactly the same.
Re: jdm gsr motor
Or just wire up the sensors, god knows that won't take longer than 30 minutes. It's just so easy when you have everything at your disposal.
Re: jdm gsr motor
first of all??????? how do u chip a obd2 ecu i didnt know thats possible i know obd1 you can chip..i have a 96 coupe and 01 jdm gsr. goin from obd2b to obd2a.. i dont think there is a chip for that to eliminate sensors. does any one have the wire diagrams for the knock sensor i have the one for the crank sensor.
Seagull Management
Re: jdm gsr motor
Below are the pinouts you will need, as well as the CKF fix. Using a manual '96 - '98 EX harness will take care of the vast majority of the wiring btw. Using a DX harness you will need preform the IACV fix (shown below, and wire in the knock sensor)
CKF Fix ---> http://technet.ff-squad.com/ckftrick.htm
All pics courtesy of Katman @ ff-squad.
Re: jdm gsr motor
ok. i have an ex civic harness and not a dx harness so i dont understand why the knock sensor needs wired. im new to the whole wiring thing its alot to take in. thank you for the cky diagram i appreciate it
