jdm gauges question
jdm gauges question
i have some jdm gauges from a 92-95 sir in my 93 ex coupe. everything works perfectly except for the tach. would the tach not work correctly because of the dohc -> sohc difference?? im not sure why it doesn't work.
search brought up nothing either.
Re: jdm gauges question (ridiculous)
the sohc/dohc does not make a difference at all. Thats all I can help u with man, sounds like it could be screwed....wait for more opinions
gauge clusters are interchanablge as far as 92-5 civics go regardless if its a euro, JDM or USDM or model or type, all will work and are plug and play. check the connection between tach wire on the dizzy (blue wire) to the plug cluster. make sure the needle isn;t just stuck or cracked either.
Re: jdm gauges question (eg6ajk)
the same thing happend to me... the needle was somehow turned around counterclockwise past the needle stopper. All i did was turn it back clockwise over the stopper. Be careful not the break the needle off.
-rich
-rich
Re: jdm gauges question (8grandEG)
well the needle moves, but it idles at like 4.000, and is always way higher than it should be. maybe i will try the counter clockwise thing, thanx for the advice, anyone else??? i hate not having a working tach.
no i never dropped it, cant say that the guy who shipped it didn't though. any way to fix it you think??
aznm1tch
02-24-2013 07:42 PM
rody084
12
12-30-2003 08:52 AM
