jdm fogs on uk vti del sol
here isa few photos where do i connect plug1 and plugs as shown on my photo s many thanks gerard<iframe src="http://s1294.beta.photobucket.com/user/gerardb1/story/40507/embed" width="650" height="400" frameborder="0" scrolling="no"></iframe> if this link does not work please let me know
Re: jdm fogs on uk vti del sol
Plug one goes to the fog light harness outside the car. Their should be two harness the underdash is the one you have. Goes from the fog light to the under dash harness.
[QUOTE=Nbboy7;48462862][/QUOTE my car is uk spec 94 it has pre wired fog 2 pin plugs in the engine bay??? in a jap import del sol the2 pin brown plug is near the air filter but not on my uk del sol i can not find it
i think i might need few changes to my harness, on page 4 of the pdf i am missing white connection into 5 ??? the pdf is made feb 1992 the factory fogs where only on 94 to 96 del sols so my switch loom might be different then the one used in this pdf does that make any sense ????????
2 pin brown connector from engine bay loom , i have connected the earth on with the lug need to know where to run my brown wire to inside the car?????
Im having trouble with this too..
Ive the harness taken from a JDM del sol fitting it to my EG2 siR and cannot see where Plug 2 goes?
I never narc'd on nobody!
Plug 2 goes to a separate sub-harness. The harness pictured in the OP is ONLY the under-dash sub-harness. You ALSO need the under-hood sub-harness. Plug 2 plugs into the under-hood sub-harness, which then plugs into the fog lights themselves.
plug 1 is the brown one that goes from the under dash to the engine bay. plug 2 is the clear white one with 3 (or 4) wires. that is the one we are confused about
