JDM engine
JDM engine
I am planing to swap a H22a type S into my del sol but I had a question i was wondering if you could make an H22A type S JDM engine smog legal in Cali? Or what kind of engine do you need to make it smog legal and were can you get one.
* B A N N E D *
Re: JDM engine (macattack)
I'm not sure "which" engines you can make smog legal, however, keep in mind that the engine is going to have to be from a newer model JDM, with preferably low-mileage, and contain the same, if not more Emission standards than your factory engine; in order to pass the BAR requirements. Also, I'd suggest you drive your car to Nevada or Arizona, and have it BAR legaled, and just pay $150 to get the car passed under the table. Which year Del Sol? If your's is the Si that comes with the B16, I'd recommend going ITR or CTR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macattack »</TD></TR><TR><TD CLASS="quote">I am planing to swap a H22a type S into my del sol but I had a question i was wondering if you could make an H22A type S JDM engine smog legal in Cali? Or what kind of engine do you need to make it smog legal and were can you get one. </TD></TR></TABLE>
I had a friend that had the same problem. Just leave it completely stock. Regardless of what people say putting a V8 cat won't help. Make sure the idle is right, adjust the screw on the air billeting system. Stock fuel railing and fuel injectors and all.
its not fun and it ends up costing a bunch to do it right. Check with the Bureau of Automotive Repair
Wazup
04-14-2006 11:37 AM
SpeedDemon619
06-05-2004 01:45 AM
comptechgsr
07-20-2002 10:10 AM
