Jdm d15b waterpump?
Jdm d15b waterpump?
Hey whats up honda tech,
I need some help with finding a water pump i have read up on this but havent been able to figure it all out yet. I wanted to know if the d15b7 water pump fit the jdm d15b they look exactly the same but does it work? And also i would like to know if my water pump is mechanical? Also what timing belt would i jeed to use and what year model and trim of the car because they dont ask for the engine they ask for the car model year amd trim thanks.also what spark plugs and spark plug wires do i need? I also need the year make amd trim of the car or by sizes i really never have bought spark plugs or wires please amswer my questions it will be truly appreciated! Thanks ht!
Re: Jdm d15b waterpump?
Hope this helps ya!
D15B timing belt p/n= 14400-P08-004(103RU24 A-555) (UNITTA) <- same as Vx
D15B water pump p/n= 19200-P08-004(YAMADA) <- same as Vx/Ex/Si
D15B tensioner p/n= 14520-P2A-305 <- same as Vx/Ex/Si
SNIP
NAPA p/n's:
pump= WP 571381(OEM reman/lifetime warranty)
belt=NBH 250223(OEM part)
tensioner=NTP 95406(OEM part)
SNIP
NAPA p/n's:
Hope this helps ya!
SNIP
NAPA p/n's:
SNIP
NAPA p/n's:
Seagull Management
Which D15B? If it's the OBD1 non-vtec version or dual carbed version D15B7 stuff works. If it's the OBD1 Vtec version you need a D15Z1 (VX) waterpump and timing belt, the tensioner isn't available in North America, D16Z6 tensioner is close, but it uses a larger roller. If it's a Vtec-e version you need all VX stuff. If it's an OBD2 version I'm not sure what you need, but I would guess D16Y7/D16Y8 parts.
Correct, you can't get the exact tensioner. Mine is a Z6 tensioner with the slightly larger roller.
That p/n list is for Obd-1 D15b single stage.
I always just get a Z6 oil filter. Im sure alot of single cams use the same oil filter though.
Yea im pretty sure that mine is a single stage
Seagull Management
If it's bad then yes. If it rolls good and sounds good you don't need to. They don't fail all that often and I normally just reuse them
Honda only makes 3 oil filters: Insight, S2000, and everything else. Aftermarket oil filters will vary though for whatever reason.
This is where you have to use your keen identifying skills to narrow down exactly what it is. Without seeing pictures I couldn't tell you.
Your link isn't there.
Seagull Management
Oo shoot i thought i did put the link here it is i know its cheap but its all i could afford right now http://m.autopartswarehouse.com/sku/...gs+Best+Seller
hondur
01-16-2017 09:58 AM
1990hondaHF
08-06-2003 05:32 AM
