Jdm D15b single cam vtec oil leak need part numbers ?
I have a bad oil leak that needs to be addressed but I'm a honda noob I pick this car up for 500 bucks it has a jdm d15b motor in the car I need to find new seals and gaskets I need the frunt main crank seal the oil pan gasket and cam seal and also the distributor o ring seal I just dont know what us parts match up with the jdm motor if anyone can help me out with some part numbers that would be great
Re: Jdm D15b single cam vtec oil leak need part numbers ?
All those parts are the same on any version of the car. Take the distributor cap off, if there is oil inside the distributor the shaft seal is leaking. The shaft seal is not an official part, most people replace the whole distributor. The VTEC solenoid has two gaskets which can leak badly because there is oil under pressure inside. Rule out oil dripping down from other places before messing with the oil pan.
So all of the seals and gaskets are the same regardless of it being the jdm motor so any d series gaskets and seals will work ?
