JDM D15B idle
JDM D15B idle
Hey I just recently swapped a JDM D15b into my 92 VX hatch and the idle is bounces from 1k to 2k when cold then keeps bouncing when warm, it also sometimes doesnt bounce but idles really low... I know it has to be some vacuum leak but I cant seem to find where its coming from. Any help would be
good could it be a sensor that causes the idle to be off? is there a diagram for the vacuum lines cause I am not positive that all my vacuum lines are hooked up correctly....
If anyone could help me out it would be greatly appreciated
Re: (EF9*****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9***** »</TD></TR><TR><TD CLASS="quote">Help Please.....</TD></TR></TABLE>
help a brother out!
help a brother out!
Re: (trooper0641)
it could be a number of things
but since you said that every once and a while it will idle really low, i would have to say Idle Air Control Valve aka IACV. very simple fix, either replace it or clean the one you have for a temporary fix
i was going to say that you have either a gasket leak or one of your line fittings that come off of the intake manifold uncapped until you stated the low idle part
