JDM d15b
JDM d15b
i have a few questions about this motor. does it really have 130hp stock and does any one on honda-tech have this motor in there hatch how well does it perform and all that ****? thank you
Re: JDM d15b (JDMbitches)
i have it. all my d16z parts converted right over to it. its supposed to have 130 stock but mine was never stock. i can say mine isnt doing good right now but that is because it needs a vtec controller and at least 3 passes on a dyno. i will let you know how it does on the dyno in about 3 weeks or so hopefully.
ramin
http://www.sportcompactonly.com
ramin
* B A N N E D *
Re: (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">how is that supposed to help oregon? the first post is
flogagagdgasd.</TD></TR></TABLE>
Obviously you didn't read past it.
That was a good thread until the creator lost his mind.
* B A N N E D *
Re: (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">Obviously you didn't read past it.
That was a good thread until the creator lost his mind. </TD></TR></TABLE>
I was the Creator...lol I still cant find my Mind
Re: (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">why don't people use Y8 instead? Seems to have much more parts availability. Just curious.</TD></TR></TABLE>
First of all, with a y8 an obd conversion would be needed.
Secondly, z6s have plenty of aftermarket support. A bunch of companies make rods and pistons for them, along with cams, valvetrain, etc.
Even a d15b vtec can be built. D16 rods can be used (they're the same) and suzuki vitara pistons can be used (the pistons are shorter so they fit, d16 pistons WILL NOT FIT)
So, parts availability shouldn't be too much of a problem. I say stick w/z6 or d15b.
It does not have 130hp, more like 128hp. D15Bs are great alternative if you do not have the cash and want a little more response from your car. If you are swapping this motor in your hatch make sure to get the tranny along with it. Because if your still using your stock CX/DX/VX transmission your car will be slow as hell. Get the corresponding P08 ECU, S20 BOOO transmission and you should have a reliable pretty quick car. Good Luck
1) there is a d15b thats not vtec and is injected,
2) im probably gonna switch to either the d16z6 head or d16y8 head onto my jdm d15b i have both, and will probably test both to see which works better. i have heard the y8 works better but want to try them both. i own a d16z6 head and my girl has an extra y8 head
* B A N N E D *
Re: (1993civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex »</TD></TR><TR><TD CLASS="quote">is the d15b carbd short block the same as the d15b in japan?</TD></TR></TABLE>
Do you evan know what a shortblock include's...lol its Just the block, how would u know if it was carbd...
Re: (Oregon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oregon »</TD></TR><TR><TD CLASS="quote">Do you evan know what a shortblock include's...lol its Just the block, how would u know if it was carbd...</TD></TR></TABLE>
it includes pistons crank oil pan oil pump flywheel(sometimes) timing cover
phondataz
01-27-2007 10:00 AM
PirateMcFred
25
01-18-2006 01:14 PM
92TypeR
02-24-2002 02:14 AM
