jdm d15 swap problems... HELP me please!!!
ok, so the new d15b is in, the d15b7 is out... i've connected everything, old harness, p28 ecu...
wont start!!? anybody give me any tips? the car wont crank... put in a new starter too... weird, cause when out of the car, we tested the starter and it works... when its in, it wont work... trying to start it, we only get the fan to go on... so what relays/fuses should i look for? any grounds? i really need help!!!
setup: jdm d15b, p28 ecu, centerforce clutch, ex/si tranny... HELP!!!
UPDATED: 11.09.03
Modified by jdmsiR20 at 4:55 AM 11/10/2003
UPDATED: 11.09.03
Re: jdm d15 swap problems... HELP me please!!! (jdmsiR20)
have someone turn the key to on and hold the clutch down, while u take a wire from the bat to the stater signal. See if that works, sounds like no spark from somewhere, check bat, grounds and possible shorts.
Re: jdm d15 swap problems... HELP me please!!! (flat-blk-HB)
so the four wires coming out of the harness goes to the thermostat? and the tranny ground has to be there?
also, i'm using a b7 dizzy on the d15b... modified to work... does it matter??
the only thing i will ask you is to post picz of your engine bay so we can look at it and tell you if you missed something.
the dizzy should be fine...
yeah make sure you have all your grounds there and tight....the 4 wire ground at the thermostat housing will cause exactly what you are talking about your car doing.
make sure you can hear your fuel pump, make sure you have teh grounds on, and the two power wires at teh Fuse box in teh engien bay... make sure all good connections
Re: jdm d15 swap problems... HELP me please!!! (CIV616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIV616 »</TD></TR><TR><TD CLASS="quote">make sure you can hear your fuel pump, make sure you have teh grounds on, and the two power wires at teh Fuse box in teh engien bay... make sure all good connections</TD></TR></TABLE>
check then recheck, (i know you probilly have)
sounds like a ground...
Re: jdm d15 swap problems... HELP me please!!! (cccya)
you guys are GREAT!!!!!!!!! so i cleaned all the grounds, made sure everything was tight... now the motor cranks, but still wont start.. i'm getting closer... fuel pump works and fuses are fine... any other ideas? i'm trying to get this going!!!
thanks all!! lets get this motor running!
getting fire? getting gas? check for those...if you hear your pump then you are proably getting gas...firing order correct at the dizzy?
Re: (egcivic)
alright... its getting gas, the fuel pump is working... still cranks, but nothing else... turned the dizzy 180* to see if that was it, nope... i shall check firing order next.. also will check for spark
Re: (jdmsiR20)
this is the diagram and fuse that keeps blowing.. narrowed it down to this... also, we got a little bit of fuel, and we got spark... so why does this fuse keep blowing?
Re: (jdmsiR20)
This fuse provides constant battery power to the ecu when the key is turned off. If you are blowing this fuse you have a short between the fuse and the ecu. Im not at work right now to check a schematic but you can call me there tues through saturday and I can tell you what pin that feeds on the ecu....Paul 818-763-8245
Re: (JCimport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCimport »</TD></TR><TR><TD CLASS="quote">This fuse provides constant battery power to the ecu when the key is turned off. If you are blowing this fuse you have a short between the fuse and the ecu. Im not at work right now to check a schematic but you can call me there tues through saturday and I can tell you what pin that feeds on the ecu....Paul 818-763-8245 </TD></TR></TABLE>
thanks... does anybody have any confirmation? my babez is almost ready!!! help!!
Re: (JCimport)
Yeah also check your main relay. If your main relay is bad it will sometimes blow your ECU backup fuse. Happened to me and I couldn't figure it out for 2 days.
Also make sure your fireing order is good and that dizzy is good. I've seen too many people try to modify a dizzy and it totally mess up.
Also make sure fuel is getting to the rail. Take off the return line off the FPR or FR and crank the car. Fuel should be coming out of it.
If all else fails-You have just blown up 2 ECUs. Cuz you said both won't work. I blew up a LS ECU, to this day I don't know how and why. But I put another one in and she fired right up. Oh that was a good feeling.
