JDM B20B with vtec head in to VX EG O2 WIRE HELP??
I have a JDM B20B with a gsr head Going into a VX hatch WITH THE VX ENGINE HARNESS!!! how do i switch the 5 wire for a 4 wire O2 sensor?? searches with no result
Re: JDM B20B with vtec head in to VX EG O2 WIRE HELP?? (jdmteg01)
When I did my swap I just used the wire harness for the GSR, it was plug and play. Larry
Re: JDM B20B with vtec head in to VX EG O2 WIRE HELP?? (b204d)
im researching this problem cause im close to putting a b18 in a 97 hx. i think the 2 options are use a different harness, or run wires from the o2 sensor right to the harness on the ecu, and then just leave the harness that has the 5 wire just hangin there.
* B A N N E D *
Re: JDM B20B with vtec head in to VX EG O2 WIRE HELP?? (blackeg)
why dont you look up the wiring diagram, go to http://www.hybridgarage.com or something
Re: JDM B20B with vtec head in to VX EG O2 WIRE HELP?? (ShowTymers619)
You need to convert the 7 wire 02 from the VX to a 4 wire 02 try this http://www.hybridautomotive.com/tech/o2/
90AccordVTEC
10-12-2005 05:24 PM
navin
05-28-2003 05:32 PM
Houston Hatchback
04-23-2003 05:17 PM
Houston Hatchback
04-23-2003 05:02 PM
