JDM B16A Power steering belt?
Re: JDM B16A Power steering belt? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">What crank pulley and power steering pump/pulley are you using?
I'm guessing that it's the OEM crank pulley and pump. It's a swap from HMO...
:EDIT: I can't belive you're still around!
Former Moderator
BTW:
I looked up a 1994 Del Sol VTEC model p/s belt and it's a 4PK870, while the 99-00 Si uses a 4PK880 belt - looks like that's a good 10mm difference.
I was going to suggest the Del Sol VTEC belt, and this at least confirms that it's shorter than the EM1 p/s belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">What year is the engine? Is it OBD1?
Also did you do this swap, or buy the car with the swap?</TD></TR></TABLE>
It was bought with the swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">BTW:
The EM1 belt is already too short. I guess I could just get them at the parts store to get me a bigger belt by looking it up by part number...
Former Moderator
Re: JDM B16A Power steering belt? (EX-T)
Oops my bad.
I thought you said the EM1 belt was too long.
There are a few different pump/pulley/bracket combos your car can have, so there won't be an end-all answer unfortunately.
Can you happen to see the number on the pump itself? The mounting bracket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Oops my bad.
Can you happen to see the number on the pump itself? The mounting bracket?</TD></TR></TABLE>
I'll check that out this evening when I get home from work.
ktwanky
01-19-2007 09:51 PM
