jdm b16 w/ 250 PSI compression?
hey i have had a JDM SIR-II b16a2 (1994) in my eg hatch for over a year and its running great. I installed the ctr intake cam and did a compression test just to see how it was doing........dead on 250 psi across all four cylinders. I'm positive we did the test right.
does this seem a little high to anyone else for what i thought was a stock cr?
I bought the motor from a shop in Asia I think they said they did something to it, but i just assumed it was stock. Has anyone reached these numbers with stock cr, stock head gasket and ctr cam on a jdm b16?
Re: jdm b16 w/ 250 PSI compression? (deckster333)
i have a jdm b16 sir2 form a 93. compression is dead on at 240 across. seems like we both have the same issues. My car pulls pretty effin hard for a b16 tho. my motor was an auto, was yours?(maybe the condition of it)
Modified by sheBangZ at 7:41 AM 4/10/2006
Re: jdm b16 w/ 250 PSI compression? (sheBangZ)
yeah im just tryin to think of possibilities, the test yielded dead on 250 psi all four, i just wondering if maybe the cr was bumped up or head gasket changed. I'm trying to find out because i want to jrsc it.
Re: jdm b16 w/ 250 PSI compression? (EX-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">250 is pretty high but the cam isn't going to make your CR higher!</TD></TR></TABLE>
While it won't make his CR higher, couldn't it possibly make the compression read higher IF the cam was installed a tooth off?
Re: jdm b16 w/ 250 PSI compression? (EE_Chris)
the motor is set to stock timing andI know the cam def installed properly, does anyone know the compression numbers for a b16b type r, so i can compare them?
mine is a 5-speed
Modified by deckster333 at 7:22 PM 4/10/2006
mine is a 5-speed
In most cases, a lumpier cam will make it read lower...
Sounds fishy to me...Test done at WOT?
cute little bastard
Re: (deckster333)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 »</TD></TR><TR><TD CLASS="quote">the compression tester i am using is made by "ACTRON"</TD></TR></TABLE>
Yeah thats what I used to. The autozone one lol. I heard they could be off a little. By off I mean the numbers could be slightly lower/higher in actuality. But as long as the numbers are all the same, you should be sound as a pound.
Go Tigers!
Re: (deckster333)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 »</TD></TR><TR><TD CLASS="quote">i just got an email back from my guy at the shop i bought it from over in singapore, he said he thinks they put type r pistons in it.</TD></TR></TABLE>
I'd take that as a grain of salt
cute little bastard
Re: (deckster333)
ITR pistons would lower the compression. But CTR then maybe.
could be leaking injectors or oil getting in there somehow....i had some bad injectors in the gsr and the compression was almost 300!!!!...so check for that stuff.
Re: (freakasis)
i redid the test and only cranked a few times instead of untill the needle stops and they all go right up 245 PSI. There is a really good chance there is ctr pistons in there and as stated that would make an 11:1 compression. hmmmm gotta think about the JRSC; which pulley and tuning.
I have heard bad things about sea foam drying everything out, i ran a gas additive engine cleaner (guarenteed to pass) recently. maybe ill run it again and do another test to see if its carbon build up. Someone also told me 245-250 PSI is normal for a b16, but seems too high to me.
