Jdm B16 swap questions/problems
Hello
Just wanted some input on a couple of things, first of all I have a 93 civic hatch I'm putting a jdm b16 witch was obd2 but I switched the alternator and dizzy so I could run my p28. The check engine light comes on (I haven't tried to start it yet) and the code reads 10 Idle air temp witch I replaced but is still reading the same code. There is voltage coming out of the plug witch should rule out the plug being bad right?But the code persists. Also wanted to know if anyone knew the hose diagram and by that I mean witch coolant hose goes to what. Ive seen a lot on Google and have sorted the majority out the only one that I have left is one off of the steel water hose. It is the farthest one from the thermostat housing I have no idea were it goes.
Here is the link to the picture of what I'm talking about. Although the thermostat housing in this picture has 4 outlets mine has only 3 ( it doesn't have the last smallest outlet on the thermostat).
I probably confused you a lot if you need clarification let me know ill be more than glad to answer I just need these last 2 things before I start the car so you can see why my desperation.
Thanks
Rico
Thanks
Rico
Re: Jdm B16 swap questions/problems
That hose goes to the idle air control valve on the back of the intake manifold. Then there is a hose from that goes to the throttle body. then from that to the thermostat housing.
If it has the factory tube that connects the valve cover to the intake, the tube under that is the coolant line that runs to the thermostat housing.
cricketts801
06-04-2010 03:19 PM
B6tizzleHatch
12-04-2006 10:55 AM
90civichbsi
10-03-2002 02:49 PM
