jdm b16 obd2 swap...RATTLING NOISE...HELP
hey i just swapped a obd2 b16a in my ek. now when i start the car it makes this rattling noise. the sound is similar to a tab in a can of coke or something and its lightly vibrating. when i give it gas i cant hear it. but i prolly cant hear it cuzz my engine and exhaust is so loud. but when it goes back down to 1100 to 1500 rpm i hear it again. its definitely coming from the distributor area. maybe under my valve cover near the distributor. any suggestions??
Modified by danxdan at 10:09 PM 6/4/2005
Re: jdm b16 obd2 swap...RATTLING NOISE...HELP (danxdan)
low on motor oil? tranny oil?....valve springs?...get a fuel system/injection cleaner? ..for dirty deposits.
does it only happen with clutch grabbing? does it go away if u press down the clutch?...shift linkage hitting the exhaust pipe?
Re: (disboi2xtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by disboi2xtreme »</TD></TR><TR><TD CLASS="quote">maybe just a heat shield?</TD></TR></TABLE>
Yep It's most likely your heat shield mine doe's that too.
Re: (coupe_hybrid)
but it sounds like its coming DIRECTLY from the valve train right next to the distributor. if its the heatshield shouldnt the sound be coming from UNDER the car>???? thx for the replies btw
.Grimace
05-23-2008 10:30 AM
