ITR Swaybar Questions
Who?
I have a 95 EX and am going to be installing an ITR rear swaybar soon and have heard some conflicting stories about the D- bracket install. Do i have to use a Beaks kit or can i mount the ITR bar with the stock GSR subframe/D-bracket mounts without worrying about tear outout. (I searched this and didn't really find a good answer). I really need some help on this.
Thanks in advance, Jay
Re: ITR Swaybar Questions (Spoon EJ)
Did you check out this post? https://honda-tech.com/zerothread?id=70453
Also, wouldn't you like to take the preventive measures to prevent something from
happening rather than dealing with a bigger problem in the end?
BTW, I used a BSQ style http://geocities.com/bretq/swaybar_install.html kit on mine.
Re: ITR Swaybar Questions (unFOB4U)
anyone know what if i am using the Type R rear lower control arm? should i get a reinforcement kit or no? my sway bar had been sitting in the garage for the past 9 months.....
Thanks
Thanks
definitely use a reinforcement kit, subframe damage is expensive to fix... heres the beaks install http://www.hondatwincam.com/itr-srk.html
DreamSpeed
11-04-2001 03:04 PM
