ITR swap + 94 del SLO si SOHC VTEC,,wiring issues?
im doing an ITR swap into my buddies 94 del SLO si SOHC VTEC. i have everything covered, just except for the wiring. as in,, what else is needed to be wired up? what harness to use? what ECU?
he has 97 USDM ITR wiring harness, i was told this will plug into the DEL slo's wiring harness at the firewall?? he will be running a rechipped p28 ECU (OBDI) is any additional wiring needed??? will that harness work for me? or use the stock del SLO's? thanks to anyone that help me out on this subject.
Re: ITR swap + 94 del SLO si SOHC VTEC,,wiring issues? (JDM CRX)
First off, its DEL SOL ..................
Second.... assuming the JDM and USDM ITR motors are the same, you should just be able to plug the USDM harness into the JDM motor. Then connect that all up at the shock towers, plug in your rechipped P28 and bing! you're done.
I used a USDM ITR harness on my B16A2 (USDM Civic Si) in my del Sol Si w/chipped P28. No problems.
Steve
[Modified by stevecockrill, 1:40 PM 1/14/2003]
Steve
93delsolh22
07-17-2011 06:13 PM
digital sol
06-29-2006 12:32 PM
JDM CRX
01-14-2003 12:19 AM
