itr airbox on EG?
itr airbox on EG?
can i install the ITR airbox on an EG? are the mounting holes in the right places? i also got the mounting bracket from the ITR, if that helps any
Re: itr airbox on EG? (an2ny888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">can i install the ITR airbox on an EG? are the mounting holes in the right places? i also got the mounting bracket from the ITR, if that helps any</TD></TR></TABLE>
What engine is it mating to?
Re: (dunkd)
Do this!
Its an AEM Short Ram Cut to fit the Stock EG air it works good...IT keeps heet off of your filter and lets the air move through like you got an Cold Air.. you can put a K&N or a Spoon Filter in it too! It sounds great
Re: (enkei rpf1)
just swapped in an itr engine. the holes for the bracket are there, unfortunately they're not threaded, and i cant get a nut behind the sheet metal. any way around this?
Re: (ANOTHER_JDM_EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANOTHER_JDM_EG6 »</TD></TR><TR><TD CLASS="quote">Do this!
Its an AEM Short Ram Cut to fit the Stock EG air it works good...IT keeps heet off of your filter and lets the air move through like you got an Cold Air.. you can put a K&N or a Spoon Filter in it too! It sounds great</TD></TR></TABLE>
Damn that's awesome I need a stock airbox
DAMN , thats a good idea... You think the short ram can be hidden inside the stock gsr intake hose?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANOTHER_JDM_EG6 »</TD></TR><TR><TD CLASS="quote">Do this! </TD></TR></TABLE>
i've thought about doing this before. i might try it some time later on.
Re: (woccowocco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by woccowocco »</TD></TR><TR><TD CLASS="quote">
DAMN , thats a good idea... You think the short ram can be hidden inside the stock gsr intake hose?</TD></TR></TABLE>
I cut the AEM cold air to fit form the throttle body and the stock air box! I just replaced the crappy stock little tubeing and droped a K&N in it...Im soon replacing it with a spoon drop in! Its a great and easy do it your selfer! I notice a power increase too! Thanks for all the postive feed back!
