Issues with used jdm motor
Okay, so basically i purchased a used jdm b16a motor from tigerjapanese. I recieved the motor on a pallet wrapped in plastic wrap etc looks good right?
Well.. I go to drain the oil and about 20 ounces of water comes pouring out, and following that a bunch of pretty nasty looking oil.
SO I called up tiger and spoke with a gentleman that said new oil and spark plugs and i would be good to go and there would be no problems.
Now everyone I have talked to personally says its probably junk etc.
wat do
wat do
Re: Issues with used jdm motor
Get angry. If I'd spent that much on a motor, I wouldn't want to "settle" That's why you bought a JDM motor more than likely is to get less miles, and take the guess work out of what might go wrong like if you would have bought a swap from Joe Schmoe on craigslist.
Get angry.
Setup a return freight shipping with the company, have them pay for it, and ship it back to them. That's bullsh!t. That motor has a failed head gasket, or worse.
I brought a couple motors from tiger japanese and has never had a problem with them. But after finding a thread here ----->http://www.hondamarketplace.com/show...php?t=2581123I in the honda-tech market place, I'm starting to think I was one of the lucky few.
This is a reason I ALWAYS buy from hmotorsonline.com, send that crap back and buy from trusted and renowned sources!
Something else I see often, enthusiasts will often buy the most expensive engine they have cash for and don't have any reserve for replacement parts, they just roll the dice hoping they don't have to replace anything.
I could have easily bought a Type R engine but I bought a B18C and I had to replace the distributor and clutch. Things I always replace regardless are the timing belt, water pump, tensioner, valve cover gasket and grommets plugs and wires, belts and hoses and I have money reserved for little issues that may come up.
When I did my swap at the local DIY auto garage the on site mechanic was totally blown away with everything I was replacing.
H-T White Ops
I wouldn't want it. Got to think of (1) how it got there and (2) what damage it did being there.
Glad I got lucky and found the engine I wanted locally, test drove it in the original car, watched the owner finish pulling it from the original car and drove home with it.
Def send it back at their expense, this isnt the first time ive heard tigerjapanese messing up and sending sketchy motors. a friend of mine bought an H23A from them and they decided to skip out on including a lot of the extra parts that should have been included with the order. try tokyomotorimports.
hmotors FTW or i have had very good experience with www.osakajdmotors.com
i have orderd more then 10 engines n trans from them .. b series k series d series
all motors are very good from osakajdm..
if u chose not to send it back u could tare it apart but they should give u some sort of credit
don't touch the thing ... deffinitly send it back ... i bought b20 from them looked real good and all ... took the valve cover off and it was degusting i could scoup the oil out with a spoon it looked like pudding ..but me being like a kid in a candy store couldn't wait any longer so i just tore it apart cleaned it all up and what not and put it in ... 2 weeks later it blew up on me... but whatever it was my own stupidity ..
weary ?!?!?!? my friend orderd a trans from them .. didnt even go threw the gears when he got it .. he called they put him on hold multiple times claiming it was good when shipped... idk wtf is goin on with t.j weird tho... does anyone have a in at the better buisness bereau
If they give you **** get a lawyer... Sounds like there are enough of you out there to band together and nail these crooked ****** to the wall.
my friend bought a b20 from them to build a b20 vtec, he took it apart and one of the cylinders had a little crack in it, he took pictures of it and emailed them to the company and explained the situation and they sent him another one, didnt even have to send the old one back.
I hop you paid by credit card, charge it back. Osaka has had a horrible reputation years ago, they have done business under different names too. I don;t care if I have to pay a few hundred more with HMO, at least I know I won't be left hanging.
forvendetta
10-29-2007 03:39 PM
jdmcivicferio
01-11-2003 09:22 PM
