Issues from trying to swap a Z6 into my '97 EX. Bolts don't line up, and more.
i blew up my ex ek 97 single cam motor and i bought a vtec z6 tht came off a auto 95 eg now some bolts dont bolt up on the tranny and just wantd any advice on why i mean it luks lyk it bolts up but i didnt no if u can bolt obd1 to obd2 and i no the y8 i need harness but im gona use my y7 on the z6 if it fits for now.....????
Re: fukkin need help.....
whoa .... a lot of nothing here
cant mix and match harnesses. find a wiring diagram and rewire or some sor to of adapter (im not to familiar with honda, im unsure if they make adapters) |
lolwut?
Add another hacked up Civic to the list.
Originally Posted by JuggerNaut-CTR
(Post 47816908)
So what are you doing here?
There are a couple things wrong with this thread.
1. Thread titles should at least summarize what the problem is. 2. Thread titles should not contain profanity. I'll change it, but please keep these things in mind if you decide to make another thread. Thanks! |
Dear God,
Please make this person's spelling better - it is atrocious. Thanks, -deschlong OP: Also, make your post titles more informative... you'll get way more interest. |
Re: Issues from trying to swap a Z6 into my '97 EX. Bolts don't line up, and more.
Your y7 harness will work as I swapped a z6 into a 99 2 weeks ago. Pm me with proper questions if you want help
Off the top of my head your going to have to change the driver side motor mount. The tranny will line up fine auto or manual. If you have a ex then use ur stock ex harness cuz if you use the y7 you then gotta wire in vtec. You can either buy a dizzy adapter harness or swap dizzy cases or depin and depin the dizzy on the obd2a plug. use your p2p ecu or the p28 with obd 1 adapter harness
yea sorry yall dont understand me but i dont get it either but basically i was wanting to no if i can use the d16y7 injectors,distributer,intake,altnator on a d15b block. so far im using my d16y7 tranny on the d15b and it bolts up and all my harnesses plug in. im not tryna pop vtec rit now i jus want my car to work. now everytime i try to start the car it sounds like it wants to turn on but it dosent and its shooting gas out the intake. i put all my fluids in and i no when i took the injectors off it needs to get more gas in it but i dont no whats going on. im going over everything now but could use alil advice.
Originally Posted by 4doorekboosted
(Post 47822039)
http://i0.kym-cdn.com/photos/images/...jpg?1316330080 |
...You do realize the Y7 head is a non-vtec head, right?
yes im not trying to wire vtec up yet. i just want to use the z6 head and block on the y7 tranny and also im using the dizzy,altnator,injectors,intake manifold off the y7 to the d15b. everythings bolts up except i read a post saying the dizzy only bolts up using one bolt so it boltd with 1 bolt. i got spark my fuel pump turns on so i have fuel. i dont no if i use the firing codes for the z6 or the y7 but i tried both and still dosent start. i allready no what i need for vtec i no i need a ecu and the harnesses but im not trying to do that right now so i dont need to hear that. IM NOT TRYING TO POP VTEC i just want my car to run and dont no why its not runing.
bump
As far as I can tell, you have a complete frankenstein of a motor going on. You need to give us a full, well written break down of EXACTLY what parts are coming from EXACTLY what engine.
Ok i took the alt,dizZy,injec, and intake out of the d16y7 and put ot on the d15b. I just want to no if i can use the alt,dizzy,injec, and intake from the y7 on the d15b? Everything else it from the d15b i bought just the d15b block and head with the y8 but dont want to use the y8 intake so i have the y7 intake on the d15b... Any more advice will be appricated.
Ugggghhhh i hate Frankenengines :thud:
So you have the alternator, distributor, injectors, and intake manifold from the Y7, the rotating assembly and bottom end of the d15B, and valvetrain from the Y8? Am I understanding this completely cluster of parts correctly?
Originally Posted by furious94ls
(Post 47817088)
What do you mean illegal swap? And yes you are understanding correct
(Post 47851546)
Originally Posted by 98civdx
(Post 47852201)
Older engines in newer cars is a no go. It's on the federal level.
