issues regarding oem/depo fogs
i am having a slight issue regarding my depo/oem fogs for a eg.
basically the jist of it, it keeps popping the fuse on the power line. i did notice that the battery terminal for power was hitting the firewall(thank god no fire and fixed that) but after that i didnt have the right amp fuse for the power wire so i figured id try a 25 amp. i turned the switch on lights turned on for a brief second then shut off, i checked the fuse the fuse was fine. could it be that the relay is bad???? if so can i just buy a relay out of the local car store?
thanks for any help hopefully someone answers and yes i did do a 20 min search b4 hand on this.
cliff
cliff
Re: issues regarding oem/depo fogs (cliff666)
It could be the relay. Aut0motive relays are generally pretty cheap at the auto store.
However, it might sound like the fog light switch isn't sticking either.
Re: issues regarding oem/depo fogs (EJ2-Fluffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ2-Fluffy »</TD></TR><TR><TD CLASS="quote">It could be the relay. Aut0motive relays are generally pretty cheap at the auto store.
well thing is its in the aux slot 3 so the fogs turn on with the marker lights
With the fogs still attached and wired, remove the front bumper and set it down on the ground. Turn on the foglights and see if any more fuses pop. If they don't, then it could be possible that the metal bracket holding the fogs is touching the body of the car.
ITR.#1446
06-16-2008 09:22 PM
