Issues with a GSR swapped EM1.
So I recently bought a '00 EM1. It has a full GSR swap. It has been a very annoying project.
So the new issue it's having, that's kind of got me stumped, is: Intermittently, it'll hit a lower fuel cut than 8200RPM. Usually 6800RPM, but sometimes 7200RPM. I'll be able to redline 1st-3rd, but then try it again, and it'll have every gear and neutral hit cut at 6800RPM (or 7200). Oil level good. The things I've replaced since I bought the car: Distributor Cap & Rotor Plugs/Wires Throttle Cable Rad fan switch, and ECU coolant sensor. TPS Oil Pressure Switch Connector VTEC Solenoid Filter Fuel Filter I have a new Oil Pressure Switch and a new MAP sensor I figured I'd try, just 'cause they're cheap. Any other ideas? |
Re: Issues with a GSR swapped EM1.
You posed in the EF section.
Also that seems incredibly slow. Makes me think you have a bad sensor or other mechanical issue. You need a scan tool to really dig in. |
Originally Posted by Ryanthegreat1
(Post 51941766)
Also that seems incredibly slow. Makes me think you have a bad sensor or other mechanical issue. You need a scan tool to really dig in. It is slow here because the oil pressure switch connector was corroded and the wires broke off, so VTEC wasn't even engaging. It has a new connector now, VTEC works, it still does this. My buddy pointed this out, maybe it's the issue: Is the P2t Si ECU good for a GSR swap? The P2t is for a 2000 EM1 (the car), the engine is out of a '99 GSR. Both OBD2. |
Tune is probably way off. Hard to say exactly what is happening without a scan tool.
(Post 51941799)
No, not even close. Will it run? Yes.
GSR had features the B16 did not have like variable intake runners. GSR is going to make a lot more torque and that requires more fuel. The P2T PCM is not going to have that tune loaded. It might be able to compensate on fueling a little bit but timing is going to be off and VTEC window. Might even be pulling timing due to knock. You need either a GSR ECU or a way to tune what you have. |
B18C1 swapped EM1 having some issues.
Accidentally made the other thread in the EF section cause I wasn't paying attention. Sorry mods >.<
So I recently bought a '00 EM1. It has a full GSR swap. It has been a very annoying project. So the new issue it's having, that's kind of got me stumped, is: Intermittently, it'll hit a lower fuel cut than 8200RPM. Usually 6800RPM, but sometimes 7200RPM. I'll be able to redline 1st-3rd, but then try it again, and it'll have every gear and neutral hit cut at 6800RPM (or 7200). Oil level good. The things I've replaced since I bought the car: Distributor Cap & Rotor Plugs/Wires Throttle Cable Rad fan switch, and ECU coolant sensor. TPS Oil Pressure Switch Connector VTEC Solenoid Filter Fuel Filter I have a new Oil Pressure Switch and a new MAP sensor I figured I'd try, just 'cause they're cheap. Has the stock EM1 P2t ECU, which I've read should be fine for a GSR swap, but maybe not? Any other ideas? Here's a video of what it does: |
Re: B18C1 swapped EM1 having some issues.
You sure its a p2t ecu?
Originally Posted by tony_2018
(Post 51942071)
(Post 51942071)
https://honda-tech.com/forums/honda-...d-em1-3337486/ |
Didn't miss much, he's running a p2t on a gsr. your CEL works? comes on and off when you key on?
(Post 51942123)
Originally Posted by MetalMatty
(Post 51942254)
They have the bulb pulled, but the only codes in there are for the two 02 sensors cause the assholes cut the wires, and a crank sensor.
Gotta know how these threads work brah. They always leaving details and shit as if it don't matter.
(Post 51942254)
:wack: |
(Post 51942254)
