Intermittent Electrical Issue 94 DX
#26
Re: Intermittent Electrical Issue 94 DX
Does the ECU have a warranty?
If you did the test exactly as I mentioned, it eliminates only the ECU from the fuel pump circuit. You said when you did the test, the pump always primed, but when you reconnected everything and used the key, the problem returned, thereby pointing to an ECU issue. Repeat the tests to see if you get the same or different results.
#27
Do the tests multiple times. If the pump runs every time you ground A7, but the pump intermittently fails when you turn the key with everything plugged in, the ECU is likely the problem.
There are also a couple of electrical tests that can be done to verify.
#28
#29
I put ground to A7 and every time it works I turn the key on it turns on I turn it off the pump turns off. Works like a charm every time when i supply the ground but does not work when I plug in the connector... Even though this is a new ECU.
#35
#36
Unplug ECU connectors A and B.
Turn key to ON(II).
Measure voltage to body ground at ECU connector pins A25 and B1.
Turn key OFF.
Measure continuity to body ground at ECU pins A23, A24, A26, and B2.
http://www.phearable.net/images/tech...schematics.gif
Turn key to ON(II).
Turn key OFF.
#37
Turn key to ON(II).
Turn key OFF.
Turn key to ON(II).
Turn key OFF.
#39
Turn key to ON(II).
Turn key OFF.
Turn key to ON(II).
Turn key OFF.
#40
#41
S375CRX
08-21-2014 07:36 PM
SiRkid
03-13-2008 04:04 AM
CornFlake340
08-19-2006 08:15 PM
