Interior Color difference between an Si and a DX...
does anyone know if there's a difference in the color of the plastic pieces in the interior? I'm thinking of purchasing the plastic that goes around the shifter and holds the cupholder and pocket but i wasn't sure if both colors were the same. I have a 98 civic dx with medium gray plastic and the guy says his 00' si plastic is grey also....just wanted to make sure both were the same color before i made the purchase...any help would be appreciated. https://honda-tech.com/forums/images...es/emsmile.gif
Have you checked your interior color code yet? It's in your driver's door. It will be near the door latch if you have a coupe or hatch, and near the bottom of the driver's door corner (along the same jamb as the latch is) if it's a sedan.
If it's Type K colored interior, there is no difference. The Si does not come in an exclusive interior color. https://img206.imageshack.us/img206/...rcolorsnz3.jpg |
Re: Interior Color difference between an Si and a DX... (koosimano)
there a slight shade off i think the dx is a bit darker and the material that goes on top of the arm rest is different, it's suppose to match your seats i have a friend who put in a arm rest in and the other piece around the shifter and it's a shade different cant remember exactly which one is darker he put a 98 si (Canadian) arm rest in his 98 dx
Re: Interior Color difference between an Si and a DX... (98greensi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98greensi »</TD></TR><TR><TD CLASS="quote">there a slight shade off i think the dx is a bit darker and the material that goes on top of the arm rest is different, it's suppose to match your seats i have a friend who put in a arm rest in and the other piece around the shifter and it's a shade different cant remember exactly which one is darker he put a 98 si (Canadian) arm rest in his 98 dx</TD></TR></TABLE>
The car you're referring to must have had a light gray interior. Many other cars besides the Si have dark gray interiors. Hell, my '98 EX coupe has a dark gray interior even. And yes, it's stock. Just like my '97 EX coupe had and Eran's '97 CX hatch. So, no, it's not necessarily going to be a shade off. |
Re: Interior Color difference between an Si and a DX... (NOFX)
thanks for the great help.....i haven't looked inside my door jam yet but i'm assuming that the difference between the two grays are pretty obvious? i have some pretty light grey dx seats btw mine is a coupe....but the interior plastics are darker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koosimano »</TD></TR><TR><TD CLASS="quote">thanks for the great help.....i haven't looked inside my door jam yet but i'm assuming that the difference between the two grays are pretty obvious? i have some pretty light grey dx seats btw mine is a coupe....but the interior plastics are darker. </TD></TR></TABLE>
Well, I'll put it this way... I haven't been able to set up a chart of what interior color matches to what exterior color because dark and light gray look too close to the same in photos unless you have a comparison against the other color. If you were to put dark gray parts into a light gray interior car, you will definitely be able to tell. |
