integra control arms needed in drum to disc swap?
Re: integra control arms needed in drum to disc swap? (slow_civic)
96-2000 civic, no they wont fit, use si arms
92-95 civic, yes almost positive they fit and work.
Re: integra control arms needed in drum to disc swap? (civicdisobedience)
Re: integra control arms needed in drum to disc swap? (C1V1C)
yes they do fit 92-95, not necessary though unless you want to add a rear sway.
Re: integra control arms needed in drum to disc swap? (owen_the_soyboy)
you do not need integra control arms for a rear disc conversion. The only thing you would need them for is if you want to install a rear sway bar that uses oem mounting locations.
JasonKarl
10
08-22-2007 04:59 AM
truevietluv636
07-31-2007 10:22 AM
