integra clutch pedal in civic?
i got an integra clutch pedal along with the bracket to mount it on my EK civic firewall. will this work? do the integra (out of a 96) and EK civic clutch pedals and brackets have the same mount holes and hook up to the clutch master cylinder the same? basically, will the integra one work properly and use all the proper mounting positions in my EK civic? will the electrical aspects of the integra one like the switch to start the car with the clutch pushed in work? does the civic female terminal plug directly into the integra male terminal without modification?
also, since the clutch pedal assembly is out of the car and not hooked up to the clutch master cylinder, is it normal for the clutch pedal to not have any spring to it like the brake and gas pedals? when i push on the clutch pedal (not mounted in the car yet) it snaps back all the way and if you lift it to make it go back to the normal position, it quickly springs back up. there is no inbetween, like you could not hold the clutch pedal inbetween the normal and fully depressed position. when you hook it up to the clutch master cylinder, does it then act like a normal clutch pedal having that same springy feel to it as the brake and clutch pedal? man i hope that made sense.... |
Re: integra clutch pedal in civic? (deviant1)
ttt....need help on this please
help please
bump
