integra brake swap
i want to do a integra brake swap on my eg but i need to know EVERYTHING that i need to find used or buy new to complete this swap, including the MC and prop valve. can anyone help me out on what i need. thanks
Re: integra brake swap (bdicustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdicustoms »</TD></TR><TR><TD CLASS="quote">i want to do a integra brake swap on my eg but i need to know EVERYTHING that i need to find used or buy new to complete this swap, including the MC and prop valve. can anyone help me out on what i need. thanks</TD></TR></TABLE>
Front? Rear? All the way around? Be more specific https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: integra brake swap (SpydiR)
Re: integra brake swap (honda9369)
i think its rear lca's, rotors, calipers, pads, brake lines, ebrake cables, prop valve, id personally upgrade my mc and booster also.
Re: integra brake swap (bucbaby)
front and back, everything that i need to do the swap.
bump
can someone help me out???
are you going to be using an integra booster or a civic booster? if your going to be using an integra booster i have a 1" m/c for you.
Rear:
Trailing arm assembly(callipers, rotors, rear trailing arm, and a ton of little things. Just ask for the rear trailing arm assembly at the junk yard.) Flexable brake line with the banjo bolt.(most people cut them, and they are about $50 a side from honda, or $25 for off brand Shmuks ones.) Rear Options: New control arms with swaybar mounts Rear swaybar Endlinks Front: Front Knuckle (again, just ask. Rotor, caliber, brake lines, all that good stuff.) Front Options: Control arms Front swaybar Endlinks |
Re: integra brake swap (elwood)
You can get a 91 civic ex four door MC. It bolts right to EGs without bending the brake lines. It works with the stock EG prop valve. Its a 15/16" MC. It works well with Integra brake swaps on civics. Cost ~$60(with core) at local auto parts stores.
A lot of people around h-t have this on their EGs. |
