Integra Airbox into Eg?
Solbros Owns Me
Re: Integra Airbox into Eg? (Steady)
it will fit.
it will be a little loose over the throttle body unless you have a B series throttle body in your car. If not, it's a 2mm difference in diameter
Re: Integra Airbox into Eg? (Emerica)
Solbros Owns Me
Re: Integra Airbox into Eg? (ThunderLips)
well Mike, seeing that the diameter of a D series throttle body is 58mm and B series excluding Type R is 60...60-58=2.
It will fit fine, just make sure you tighten the clap enough so the neck doesn't move around on the throttle body.
the world is a vampire
It fits pretty bad. I tried it myself last week. The airbox itself will sit about 1mm away from your radiator over-flow tank and only one bolt (the one closests to the firewall) will line up. Also, the inlet hangs off the frame rail instead of over the hole like in EG's chassis. After I tried it, then immediately switched back to EG airbox, I thought to myself "wow, what a waste of 5 minutes"
the box will fit only if you dont have ac, the lines are all in the way otherwise. and i definately think the tube will fit to the tb no problem, if the diameter is alittle off just call aem and see if you can order a rubber coupler from them for about $5. that'd be my suggestion anyway.
im waiting to take my ac out to put my itr box in, my short ram tube is the perfect size, diameter, and bend so it will work no problem.
Re: Integra Airbox into Eg? (b16a ferio)
Re: Integra Airbox into Eg? (euclid)
yeah you are right abou tthe bolts too, you will need to drill a hole in order to mount up a second mounting bolt.... i wanted an icebox but they are like 150$ so i got an itr aibox(same exact dimensions as comptech) and now have a diy icebox waiting to be installed for a total of 40$
Sent to drain...
but since it serves such an "important" purpose they can mark it up by 7500%
Solbros Owns Me
Sent to drain...
it sucks. i think alittle honesty and integrity goes really far. if i went to walmart and bought a tuppermaid tub that used the exact same type and quantity of plastic as the comptech icebox, i would be spending about $2.75
My little quote had nothing to do with this thread, just a little remark towards my buddy Mikey...who is deeply intrigued by Billy Corgan.
Bringing back an old post from the grave... Sorry in advance!
I recently bought a CT Engineering Ice box for an Integra (94-01 LS/RS/GS/GSR/Type-R) for my '94 EJ2. I currently have my stock engine (D15B7 FTL) with a/c. The box itself fit pretty snug and I did not use any of the hardware that came with the kit. I ended up securing the box by "zip-tying" it down. I am also using the stock air intake with a cheap STP air filter (SA7600) for now while; High flow foam air filter on order
*Edit* I didn't want to make a new thread to spread this "knowledge" and this is the only thread topic that I found that would make sense to post this under. Not too much info. for installing an ice box into the EG chasis out there
