intalling sppon front lip on EG?????
Re: intalling sppon front lip on EG????? (jdmitrhatch)
If it doesn't have predrilled holes or markings to tell you where to drill, just make your own holes. You want have enough holes to secure it. I used one in the front, right in the middle, then worked my way around from there. I have 5 total on the bottom, using a nut/bolt/2 washer combo, that you can find at Home Depot. Also 1 wood screw in each side, where the lip wraps around the bumper, near the wheel.
You can screw it wherever it meets up. Use the stock holes in the bumper to mark your drill spot. I personally wouldn't use that many screws, but you can.
