Intake Question
Intake Question
Hello Everyone! I would like to pick your brain with another question.
I recently got a 94 coupe and swapped my gsr into it. I hate how the intake looks. And I do not want to run a cold air intake. I would like to run a stock intake from a civic. I am currently running a stock intake from an integra. I know that I can get a oem box and bolt it up just fine. My question is as fallows, "can I use either a vtec del sol elbow, or a eg6 sir elbow with the box on my GSR?" I have seen this done on b16 swapped civics, but the intake manifold on a gsr placed the throttle body a tad lower and in an overal different location. Has anyone tried this to know if it will fit?
I can get a vtec del sol elbow from work for only 50 bucks. If it will work that is the way I will go.
Thank you everyone!
Thank you everyone!
Re: Intake Question
Thank you everyone!
Thank you everyone!
So you must use the GSR elbow if you want to use a OEM setup.
I would suggest using a JDM SIR2 airbox, (which should have a larger inlet then your stock airbox on the civic) And see if the GSR elbow will reach/work with it. Do a little mcguever to make it work??
Top it off with a quality high flow panel filter.
Look into comptech/CT engineering for intake solutions that come with a CARB sticker, and is sold at your local Acura dealers, or online.
Closest to OEM look and fitment you will see from the aftermarket
HopperIsMyCar
12-09-2011 09:09 AM
msgboardking
02-22-2006 06:46 AM
