instructions for itr swaybar install?
Re: instructions for itr swaybar install?
http://hybrid.honda-perf.org/tech/6gitrsway/
Try that. Its got pictures
Re: instructions for itr swaybar install? (merritr)
thanks for the link, but i checked that one out too. how the hell can you bolt up the si endlink to the swaybar? the endlink is to short i can't thread the nut in does anybody have a suggestion as to how i can get it to thread in?
Re: instructions for itr swaybar install? (xlr8si)
attach the endlinks then raise the lcas to meet w/ the swaybar (thats if your car is raised using a jack)
Re: instructions for itr swaybar install? (SuperTwinz)
Well if you read the article carefully it explains the problem you are having. There is a metal retainer in the hole in the sway bar. The retainer is inside bushing. You just take out the metal retainer and the bolt with fit through. Since the bolt will now just be going through the hole in the middle of the bushing you should be able to squeeze it trough since the bushing it soft and can be squished.
[Modified by merritr, 7:53 PM 12/7/2001]
The bushing will last (it isn't a necessary bushing anyway), it just might rip out of the sway bar like mine did. However you might also rip your subframe. I just put a washer on before the bolt so that it would not rip out of the sway bar. That still doesn't solve the subframe problem though.
[Modified by merritr, 8:12 PM 12/7/2001]
I talked slightly about how and why NOT to use the ITR endlink bushing in this post:
http://civichatchback.zeroforum.com/zerothread?id=4879
I also make the kit described. Hope it helps.
-Wil
-Wil
beanbag
01-20-2006 09:05 AM
