Installing Skunk2 Short Shifter
Hey, I just picked up my skunk short shifter kit today and by the looks of it, I know I'll be happy, but that knob is like a dead weight https://honda-tech.com/forums/images...s/emsmileo.gif
Well anyways, can anyone help me with sort of like a step by step on how to install it, or some kinda info at all would help. Thanks |
Re: Installing Skunk2 Short Shifter (Sassafrass)
Anyone help me out?
It's freakin' easy! You don't need any help! Get under the car and figure it out. Buy a manual for your car. <---- That's my $.02
Re: Installing Skunk2 Short Shifter (4DeepCivic)
first off, take off stock shift knob, then jack up car and put on jack supports.... then crawl under the car, unbolt cat from ehxuast manifold, let it drop down, undo the 2 12mm bolts that hold up the shift linkage under the shifter, there are 2 10mm bolts under there undo them take out stock shifter and use stock stuff on the new shifter and put back together, its as easy as that, good luck https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Installing Skunk2 Short Shifter (coptzer)
http://importnut.net/shifter.htm
this should help ya |
