Installing a Short Shifter
Old 06-13-2003, 11:32 AM
NetRyderz's Avatar
Default Installing a Short Shifter
Sup All!
Anyone have any steps to install a short shifter on a 2000 Civic? I think there was a site that had directions but I can't remember the link.
Will I need to jack the car up and have access underneath? Or will I be able to do everything from the top?
Thanks!
Old 06-13-2003, 11:42 AM
JDMy0's Avatar
Default Re: Installing a Short Shifter (NetRyderz)
no jack required, everythin is done from the inside of your car.. just take out the console and replace parts. gl
Old 06-13-2003, 11:44 AM
FifthGearOnline's Avatar
you will need to get under the car. once you get under there you will have a good idea as to what needs to be done. you must get under the car so that you can unbolt the shift linkage from the stock shifter
it will take about an hour to an hour and a half
Old 06-13-2003, 11:50 AM
NetRyderz's Avatar
So...which is it?
Under the car or inside the car?
Old 06-13-2003, 11:51 AM
PotatoePAPA's Avatar
Default Re: (FifthGearOnline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FifthGearOnline &raquo;</TD></TR><TR><TD CLASS="quote">you must get under the car so that you can unbolt the shift linkage from the stock shifter</TD></TR></TABLE>
under the car
Old 06-13-2003, 12:09 PM
Gump's Avatar
Default Re: (SleepyDX)
It's both! You will work under and inside the car.
Modified by Gump at 1:26 PM 6/13/2003
godnf8's Avatar
both
Old 06-13-2003, 12:18 PM
Default Re: (godnf8)
good call. both.
Old 06-13-2003, 12:58 PM
00MRSi's Avatar
Default Re: (Gump)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gump &raquo;</TD></TR><TR><TD CLASS="quote"> It's both! You will work under and inside the car.
Modified by Gump at 1:26 PM 6/13/2003</TD></TR></TABLE>
If you can put it on a lift, it'll be much easier..
Old 06-13-2003, 01:05 PM
Default Re:
oh yea, when you get to the point where you have to take the bolts that have a flat top on them, get some needle nose vicegrips and clamp them down on them from the inside, go back under, hold the vicegrips and use your socket to take the nut off.
thats the hardest part, and its mostly just annoying
bomber19
09-24-2007 03:56 PM
vietherbs
04-19-2007 10:32 PM
ProjectCD5
02-21-2006 11:55 PM
krisjk2
08-16-2005 05:52 PM
92BluEH-3
06-20-2005 06:10 PM
Quick Reply: Installing a Short Shifter
