installing power windows on my 94 civic si
My buddy has a '94 civic si hatchback and the passanger window keeps on falling out of the window. I was wondering if it would be easier for him to get new channels or try to convert it to power windows. We searched around, and couldn't find any info on converting to power or on window installations. Can power even be done on that series? Alright, thanks a ton.
Location: Why so you can pretend like youre interested, FL/OK
Re: installing power windows on my 94 civic si (debogsr)
Here:
https://honda-tech.com/zerothread?id=612414
https://honda-tech.com/zerothread?id=145543
https://honda-tech.com/zerothread?id=619175
https://honda-tech.com/zerothread?id=773747
In question to the window falling off track, I would suggest removing the door panel and making sure all the adjusting screws are tight. Near the bottom of the glass where the white tabs are. Mine fell off track every now and again, I replaced the bolt with a slightly larger one after testing out the window to see where and why it was falling off the track. Remove the panel and just test the window out going up and down to see if it's getting stuck or what may be causing it to fall out.
