Installing JDM Mirrors (DIY)
I decided to put a little DIY for JDM folding mirrors w/ OEM relay. There have been some out there but they may be alittle confusing or unclear.
Materials Needed: JDM Mirrors OEM Relay Box 8mm Ratchet Philips/Flat Screw Driver Paper Clip Wire Loom(not necessary) 22 or 18 guage wire Electrical Tape 1.Take off Door panal 2. On the JDM clip that connects to the switch(green) you will see that there is an extra wire on the very left side. Remove this wire and put it in the exact spot in the USDM switch clip. You will need a paper clip to remove the wire. http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D 3. You will then go the the clip that connects to the mirrors. Look at the JDM one and the USDM one. you will see that the JDM clip has 2 extra wires. Remove the 2 and put them in the same spot on the USDM clip. Use the same method with the paper clip to remove wires. http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D 4. After you have done that, use the following diagram to wire mirrors and OEM relay box. You may put the relay box anyplace you choose. I decided to put the box in the driver side kick panel. Heres a diagram on how to wire them up. http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D 5. This is how I put feed the wires from the door to the inside of the car. There are many ways to do it but I thought this is the most simplest way. http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D 6. Your finished! Hook everything back up and make sure everything works! http://www.we-todd-did-racing....DE%3D |
Re: Installing JDM Mirrors (Denny)
Looks awesome! can't wait to see them in person. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Installing JDM Mirrors (B2FiNiTY)
bad ass
Re: Installing JDM Mirrors (XSCDCXDC2)
thanks for the comments!
that's only the second vid i've seen of the power folding mirrors. badass. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Installing JDM Mirrors (nightrider)
great write up https://honda-tech.com/forums/images/smilies/emthup.gif
there a pain in the ass.. |
I'm still trying to figure out how to be able to see from the driverside mirror (JDM passengerside). All I see is the side of my car. I'm sure you probably have this problem, what have you done to get around it? Thanks!
Re: Installing JDM Mirrors (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs »</TD></TR><TR><TD CLASS="quote">I'm still trying to figure out how to be able to see from the driverside mirror (JDM passengerside). All I see is the side of my car. I'm sure you probably have this problem, what have you done to get around it? Thanks!</TD></TR></TABLE>
i have this very same problem. you can either live with it or use the blind spot mirrors. i dont even use my mirrors anyways. i just look over my sholder, so its not really a big concern. |
https://honda-tech.com/forums/images...es/emsmile.gif Good for you. With my USDM mirrors w/blind spot mirrors, I never look over since I have a complete view. Guess, I'll have to get use to the fact I wont be able to do this anymore. Sucks!
their should be a section in each forum for DIY
sometimes its hard to find old writeups.. great writeup https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Installing JDM Mirrors (NrG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG »</TD></TR><TR><TD CLASS="quote">their should be a section in each forum for DIY
sometimes its hard to find old writeups.. great writeup https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif to that!!! |
damn thats so tight I was gonna pick those up but this guy wanted $400 for um https://honda-tech.com/forums/images...s/emthdown.gif
Why the hell would you get rid of windows that work for some JDM coolguy mirrors that you can't see out of??? Seems a little like you guys have jumped on the JDM bandwagon. |
Re: Installing JDM Mirrors (yakitori)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakitori »</TD></TR><TR><TD CLASS="quote">damn thats so tight I was gonna pick those up but this guy wanted $400 for um https://honda-tech.com/forums/images...s/emthdown.gif </TD></TR></TABLE>
If I like the look of integra mirrors on mine, I will sell you a set with the OEM relay, interior switch, covers, and mirrors for $240 shipped. |
Re: Installing JDM Mirrors (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Why the hell would you get rid of windows that work for some JDM coolguy mirrors that you can't see out of??? Seems a little like you guys have jumped on the JDM bandwagon.</TD></TR></TABLE> Just remember "JDM coolguy" is your term and not mine, I honestly just like toying around with things (kid at heart). For other resources: http://students.washington.edu...3.gif http://students.washington.edu...s.htm https://honda-tech.com/zerothread?id=539424 http://www.courtlukens.com/folding_mirror.htm |
I've always liked the idea of wiring them up to your alarm, so when you arm it they fold in, when you disarm it they fold out https://honda-tech.com/forums/images/smilies/emwink.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Installing JDM Mirrors (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC »</TD></TR><TR><TD CLASS="quote">I've always liked the idea of wiring them up to your alarm, so when you arm it they fold in, when you disarm it they fold out https://honda-tech.com/forums/images/smilies/emwink.gif https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
that would be pretty tight.....and scary...muhahahaha https://honda-tech.com/forums/images...s/emsmileo.gif |
Re: Installing JDM Mirrors (HybridRacer)
Cool write up!
Any chance someone still has these pics? Or a new link? I need to do this.
Last try............
how do i get to see the pics? my comp has the pics X out
Re: Installing JDM Mirrors (a.6262)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a.6262 »</TD></TR><TR><TD CLASS="quote">how do i get to see the pics? my comp has the pics X out</TD></TR></TABLE> old thread.. pictures just need to be re-hosted. |
Re: Installing JDM Mirrors (mogge)
Someone make this happen............ https://honda-tech.com/forums/images/smilies/emthup.gif
