Installing Intenna *BACK MIDDLE*
Hey, i just took off my radio intenna and but bondo in the lil hole and such. I want to install a intenna in the back right next to my rear window. How would i do that? Thanks.
P.s. dun know if it matters i gota 93 Civic Cx
Re: Installing Intenna *BACK MIDDLE* (XHatchXcivicX)
if u removed it from where it originally was and knew you had to fill the hole, you would think you would know that you had to make another hole where you want to put it
Well, first you'll need to figure out what kind of antenna you plan on using, b/c your stock one won't work. Then you'll need to figure out what holes need to be drilled, figure out where to drill them, then drill the holes. I'd recommend having the headliner out for this. Then you'll take and run your antenna wire forwards through the vehicle on top of the headliner, and get it to your radio. Not too hard.... just think about it. Keep in mind that your new antenna will need a longer wire.
koumatae
08-02-2012 12:53 PM
Lucky-13
03-21-2007 03:52 PM
