Installing a Camber Kit
skunk2 front a-arms??
I just did my Omnipower a-arms... so I can do a write up for you:
step one: remove stock arms
step two: install Skunk2 arms
step three: get alignment
step four: have a beer
haha
it really is that simple.
on EKs the bolts are on the side of the strut towers, on the 92-95 it's on the top side of the strut towers.
haha
Re: Installing a Camber Kit (EgRedSi)
Its simple open the hood there are two bolts on the outer rim where the strut comes up, simply loosen these and push down then remove the ball joint from the hub. Its that simple make sure you jack up the car and everything also make sure to pull the ball joint on the skunk2 all the way down thats what I was told to do before I drive to get it aligned
Re: (bbarbulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">skunk2 front a-arms??
haha
on EKs the bolts are on the side of the strut towers, on the 92-95 it's on the top side of the strut towers.</TD></TR></TABLE>
Yep, front arms.
haha
Yep, front arms.
it's real easy I have them in my car...just be carefull with the bolts on the new arms....they are made of a soft metal and will snap easily, but you don't want them coming loose either...that would suck ballz....feels like wheels turn at seperate times....(cause they will)
dunce11r
05-13-2006 01:20 PM
Fuster_Cluck
20
08-04-2003 08:08 AM
