Installing axles, HELP
Re: Installing axles, HELP (Dudikoff)
They take a little bit of a quick pounding to go in.
insert the slines into the tranny.... and give it a quick punch to seat it in.
On the knuckle side of it, insert the slines , and then holding the rotor parallell to the car, give it a quick hammer forward, should go right in.
Re: Installing axles, HELP (BlueIntegraBoy)
ohh ok. so i just need to slide it in through the tranny/other side then put it through the hub then hammer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You hammer at the end of the spline.</TD></TR></TABLE>
You don't use hammer...
you insert the splines then you hold the shaft and shove it into tranny with a quick jerk
then you insert the splines into the hub, now hold the rotor and shove the hub further onto the splines
sometimes you may have to try a few times.
drewbie
06-06-2004 10:04 PM
