install sparco steering wheel
Just wondering if anyone new the size of the anan wrench and what type to get the airbag off so I could install my sparco hub
Thnaks
OK cool got the momo steering wheel on anyone can help me how 2 get the horn to work now. would apprieciate it thanks
Modified by b18_racer805 at 11:13 AM 3/15/2007
Thnaks
* B A N N E D *
Re: (Eran)
i have a snap on set, but craftsman is good for the do it yourselfer it only costs a little more in the beggining but the resale value stays and you could pass it along you're fa,miy forever
i dont trust the home depto lifetime warrantys, the lowe's one or the duralast warranty's becuase they argue about how to use the tool you were using it wrong etc etc
HT White Ops
Eh, it's a set of driver bits .... if you find a torx bolt that's seized well enough to break a driver bit .... then you've got bigger problems than the warranty on your tools.
Re: (b18_racer805)
like they said ^ t30 take them out. remove air bag remove steering wheel. replace with new wheel. the horn thin just wrap the wire around the steering column as many times as the wheel will turn lock to lock and put all the wire above the column and your horn will work.
ej6hatchie
05-02-2008 11:57 AM
chief_rucka
10-25-2002 01:39 PM
